  • 2 Replies
  • 2291 Views
FullerB
The wall mount supplied with the Essential Outdoor Camera - 2nd Generation camera isn't suitable for ceiling mounting.  Poor design ...
The mount that came with the previous version was much better and could be mounted on a wall or ceiling and the camera position could be easily adjusted.
Is there still a mount available that is the same as the old mount?
The cameras have a standard thread size, so there are lots of mounts that will work.
That includes the ones Arlo sells:
FullerB
Thanks, found what I needed
