- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Re: Essential 2nd generation noisy when turning on...
Received Essential 2nd generation external camera. When live is on and turning on microphone. There is crackling sound and noise, cannot hear or use for voice. Even taking camera indoor and leave in close room, it is still noise and feedback through camera. Would it be a defect unit.
Could be.
Can you exchange it with the seller? That is generally faster/easier than getting a warranty replacement.
Will contact Arlo support for exchange as I bought direct from their website. Thx
Update on my communication with Arlo support. It is very poor support. As an experienced engineer in telecommunication and technology. I sent video capturing the issue, try different wifi networks, including mobile, hard reset the unit, using different unit without issue. All explain to Arlo technical support, but it seems to go into black hole. Not recommend to purchase from Arlo, very poor after sale customer support.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
