Device order in feed
  • 1 Reply
  • 735 Views
wolfcreek
I was able to change the device order in my feed in the old app but cannot find it in upgraded app. How can I change device order in upgraded app?
Tap the three dots in the top right hand corner of the app while on the devices tab, from there you can press and hold on the device widget you would like to move, this allows you to drag it to the desired location.
Additionally, you can customize the dashboard as you see fit with larger or smaller camera widgets. For more information on dashboard, see here: https://kb.arlo.com/000062915/What-is-the-Dashboard-on-my-Arlo-Secure-App-and-how-does-it-work
