Newly installed gen 2 essential 2k camera installed. It’s hardwired and upon install the app icon showed green and charging.. it’s 100% charged now, the icon is no longer green but now grey.. and it does not have a lightning bolt showing charging. I’m confused because my 1st gen hardwired cameras always have a green icon regardless of charge leve
any thoughts would be appreciated
JoeFavs,
If you have a solar panel or charging cable attached to the camera, that should keep the battery level topped off. If the battery is already at 100% charge, the battery indicator will not showing charging until they battery depletes and needs to resume charging.
Will a wired gen2 essential 2k camera stop charging to prolong battery use like the video doorbell
initially the green charging icon was illuminated but not its not
amy Insight would be greatly appreciated
What device are you viewing on ... Apple or Android ?
Have you also checked on the web access ? my.arlo.com
I’m using the apple app.. the gen 1 cameras have a green icon that remains on .. curious why gen 2 does not indicate the same.. wondering if it’s a battery saving thing..
JoeFavs,
Thank you community
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
