- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Re: Can't install Arlo Essential XL outdoor 2nd ge...
Novice to security camera. Got wireless as wired would be difficult to set up. Mistake? Have ISP AT&T router. Service through Sonic Net. 5 GHz with only one name.
Turned off 5 GHz. Set to 2.4 so Arlo will connect. Five trials. Pressed button on top, blue light flickering five trials. Tried Amber light sequence three times. WiFi and Arlo App password on Samsung A25 phone is correct. But get persistent message password incorrect. It's not recognizing wifi/network? How to make it see movement, capture pictures, and transmit to camera?
Told I can call the router different name. Would then see two different networks from mobile phone, then how to choose the one for Arlo?
Are there security cameras that use 5 GHz? Do I have to reduce the speed to change the security cameras every time take them down to recharge or only initial setup? Do I need to update the Arlo app and/or the camera? Talking with support for three hours did not help. Will appreciate help. Thank you.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
