- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Can abandoned Arlo cameras be reused if I purchase...
Can abandoned Arlo cameras be reused if I purchased a new base and registered for a new subscription
I have (4) arlo outdoor cameras with solar panels left by a previous owner. Can I buy a new base and register for arlo account and sync abandoned cameras to a new base?
Maybe. It depends on whether the cameras were removed from the previous owner's account.
Some cameras don't require a base. Do you know what model these cameras are?
If the camera opens, you can remove it from the housing and take out the battery to see the model. If it doesn't, then there should be a faint model number printed around the gasket where the charging port is. It can be hard to spot, as the contrast is low and the text is small.
I will pull cameras down and check model number. I wanted to check if it was even worth the hassle to get them to work. Sounds like unless the previous owner has released or removed the cameras from thier account the cameras are pretty much usless is this correct?
That is correct.
Though if the previous owner still has them in their account, then they can still see video on your property.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
