- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Arlo Essential wont charge with solar panels unles...
Arlo Essential wont charge with solar panels unless restart
My Arlo Essential Camera with solar panel will not start charging unless I do a camera restart from the App. It's within the operating temperature range, all software is updated. Sometimes it does work without a restart but almost always I have to restart it.
megatec45,
Does this behavior only occur with the solar panel? If you connect a standard charging cable is the behavior the same?
I've only used the charger once and it works, so I'm pretty sure it only happens with the solar panel.
Sorta same issue then I ended up moving the solar panel. Now error indicator says low battery power and it’s not connected to my WiFi like the other 2 are! Trying to avoid getting up on ladder to reset. Is this common? Haven’t reset from unit?
That sounds like the panel connector isn't properly seated. Did the camera battery icon ever display a lightning bolt through it when the sun was hitting the panel? If the battery is dead (which seems likely), you'll have to get it charged before anything will work.
It's seated properly and the cord isn't damaged. It's a software issue. Once I restart the camera through the app it starts charging
megatec45,
I encourage you to open a ticket with the Arlo support team to further investigate this behavior. You can find options to contact Arlo support by logging in to the Arlo Secure app and navigating to settings > support.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
