- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Re: Arlo Essential Outdoor 2nd Generation VMK345...
I am having trouble with batteries holding a charge. I have done all the suggestions on the website, According to the website the battery should last for 3-6 months and it hardly lasts 3 weeks. I even turned it off on my phone. I have been trying to call Arlo and I have got nowhere. Please help, because it gets frustrating having to keep recharging the battery.
2 things generally are the issue of rapid battery depletion:
1) Signal strength/quality between the camera and router. Move a camera closer to the router to test. Look for other 2,4GHz wireless devices near the camera which may be interfering with the signal.
2) Too much recordings and live viewing with <5 minutes per day total being the general guide. If you have activity zones defined, remove them since the servers may be deleting videos giving you a false sense of usage. Add up the total number of minutes:seconds of recording (and any live viewing you may be doing) to see if you're under that 5 minute guide.
I’m having the same problem, same setup with solar panel, brought camera in and charged it to 100%. After 3 days it’s down to 35%. Has been working fine for about 8 or 9 months. Also not charging from solar panel, and I did clean the panel and the connections.
180 degree
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
smart things
Unknown charges
VMC3050
