Arlo Essential Gen 2 outside USA
Hi, after purchasing an Arlo Essential Gen 2 in the USA and bringing it to Brazil, I'm facing the same issue that many others have reported here.
The app doesn't list the Gen 2 option.
The official support from Arlo responded that the app does not support other regions.
The workaround is quite simple: just create a new Arlo account using the US region.
Start by selecting "Create a new account" from this Arlo Community Site (https://www.arlo.com/community/register/default.aspx) , and then log in to the app using these new credentials.
PT-BR
Após comprar um Arlo Essential Gen 2 nos EUA e trazê-lo para o Brasil, estou enfrentando o mesmo problema que muitos outros relataram aqui.
O aplicativo não lista a opção Gen 2.
O suporte oficial da Arlo respondeu que o aplicativo não oferece suporte para outras regiões.
A solução é bem simples: basta criar uma nova conta Arlo usando a região dos EUA. Comece selecionando "Criar uma nova conta" neste site da Comunidade Arlo e, em seguida, faça login no aplicativo usando essas novas credenciais.
Generally the suggestion is to use a VPN that terminates in the US (or some other country where Arlo offers subscriptions) when you create the account. Disconnect the VPN when installing the camera
You will also need a payment method for that country.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
