- English
- Cameras
- Arlo Essential Outdoor 2nd Gen
- Smarthub VMB4540 not compatible with Essential 2nd...
Does anyone know when the Essential 2nd generation cameras will have a compatible Smarthub?? Through much searching as to why the hub will not sync to the cameras, I have found out that the hub I purchased-VMB4540 is not compatible nor are there any available that are. Very frustrating as I am trying to get my home security set up as soon as possible. I cannot return the cameras so I am stuck. A good bit of the listing info on the sites selling the hubs either do not specify it is not for the Essential 2nd gen or erroneously say that they do. That is how I ended up with a hub I cannot use. I want it for local storage. I am hoping a hub will be available soon. I am perplexed as to why there isn't one compatible now...
Thanks and I await a reply.
2nd generation devices are now compatible with Base Stations/SmartHubs. You can read more about this here: https://community.arlo.com/t5/Announcements/Essential-2nd-Generation-devices-are-now-compatible-with...
Arlo has said that they will add smarthub support for the 2nd gen cameras, but they haven't said when. Hopefuyll it will be soon.
Although Arlo hasn't given details. I believe that when they do that, the cameras will be able to be paired with your VMB4540 smarthub.
Any updates from arlo ?
While we still plan to provide an update that allows 2nd generation cameras to be compatible with base stations and SmartHubs, I do not have an ETA at this time.
Any updates on the timeline?
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
