I have purchased a new Essential outdoor gen 2 camera and was informed that I needed to upgrade my arlo app. I have two other cameras, previously installed, that appear in my local library. However, the new camera videos don't show in the library. Any help with this will be appreciated.
What is your active mode as shown on the Dashboard? Only the Arm Away mode will have rules for the new cameras. You will need to edit the other mode(s) in Routines to add appropriate rules there.
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
@Red15Baron wrote:
my local library.
"local"?
- What hub model do you have? Look for a VMBxxxx label on the hub.
- Do you have direct access to local storage set up? https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
- Are the new cameras connected through the smarthub? Or are they connected to your home wifi?
Thank you for your quick response, my hub is a VMB5000. The two cameras that were previously installed appear on my local (Stored on SD card) However the new camera only shows on the cloud. When I click on “Devices” the view of the two original cameras appear, there is an icon in the bottom right corner that looks like a SD card. However, the view of the new camera has no SD card icon in the bottom right corner. Is this a clue to what the problem might be?
At least on Android, none of my cameras connected to my hub have an icon for local recordings. However, the web client does show them.
You didn't answer how the new cameras are connected. If they are using your home WiFi, they won't have local recordings since the data has to pass through the hub to be recorded.
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
