Hello,
How do I activate the 4 month free subscription included with my Costco purchase.
Also, we bought one set of 3 cameras, and then bought a second set of three cameras. All will be on the same account. I added the 4th camera and it will not let me set up activity zones, it keeps wanting me to buy a subscription. Is there a way to add the second set of three cameras to get the same trial?
Thank you!
It should have activated automatically when you installed the cameras. Though I am not aware of a 4 month trial (it used to be 3 months, but was then dropped to 1 month).
Maybe try contacting paid support using the app. Select a camera that is already in the subscription plan, and that will let you get phone support with the least friction.
The Costco 4-month trial is automatically applied after onboarding the cameras. Each trial is specific to the individual camera, so whenever you add an additional camera, a trial for that camera will be applied.
You can check your subscriptions to make sure the trial is active by following these instructions: https://kb.arlo.com/000063052/How-do-I-change-or-cancel-my-Arlo-subscription-plan-Arlo-Secure-4-0
180 degree
alerts
Alexa
Android App
animal
api_key
Arlo
Arlo 2nd Gen
Arlo Cameras
Arlo Essential 2nd Gen always goes offline
Arlo Essential Spotlight
Arlo Secure 4.0
Battery life
Battery.
camera
connection
constant
customer service
Doorbell reset
drained battery
Essential
Essential Camera feature request
Essential outdoor
freeze
Google Nest
Idk
motion
motiondetection
need help
network
New features
Night vision
No recordings
not working
Orbi
Payment
privacy zones essential 2k
problemshooting
Product
Record
Reliable
returns
Router
sensor not working
Siren
smart things
too many
Unknown charges
VMC3050
