- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo-Essential-Indoor-QA-2021-04
- Does it integrate into Hub for Arlo Pro 2
Options
- Mark Question as New
- Mark Question as Read
Essential Indoor Camera can connect directly to your home router via 2.4GHz WIFI network, it is a wired camera that is powered by a USB cable and a 5V 2A power adapter. With the subscription, you can enjoy the benefits of smart notifications and 30-day cloud storage.
Alternatively, you can also connect your Essential Indoor Camera to an Arlo SmartHub or base station, through which you can save video and audio recordings to a local USB or micro SD device. Arlo Essential Indoor Camera supports model VMB4000, VMB4500, VMB4540, and VMB5000, you can check your Pro 2 Hub model for the compatibility.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
0
Likes
