  • 2 Replies
  • 1261 Views
BERTIC
BY camber setting is set for 5 mins, It will only record for 10 to 15 sec. what am i doing wrong?
The usual issue is a poor signal between the camera and router. If you move the camera to a different outlet, perhaps in a different room, does it work better?
The max fixed recording length is 2 minutes, not 5.
I think you have actually set the camera to record until motion stops (which usually is much shorter that 5 minutes).
Try using a fixed recording length of 1 minute, and see if the recordings are consistent with that setting.
  • 2 Replies
  • 1262 Views
