Will not charge
  • 1 Reply
  • 725 Views
Mattgoehring
Camera is only 2 months old and will not charge. Can’t reset as it’s totally dead.
You're in the Essential Indoor Camera section - I assume you mean a different Essential camera? The indoor camera has no battery.
If actually a battery-operated camera, can you verify that you're using the Arlo-supplied charger and cable?
A good idea is to proactively charge the battery when it drops below 25% or so or when you get the email telling you the battery is low. That way it won't completely discharge. This FAQ may or may not help since it's written for a different model:
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
  • 1 Reply
  • 726 Views
