- English
- Cameras
- Arlo Essential Indoor Camera
- Re: Is the Arlo Essential Spotlight a Pro 3 or Pro...
Can you tell me if the Arlo Essential Spotlight Wire-Free Indoor/Outdoor 1080p Security Camera is compatible with my Arlo Pro 3 Hub VMB4540r2? Also does it take the same battery as my Pro 3 camera’s? Will my current solar panels work with this camera?
Yes.
No, the Essential camera is fully sealed and the battery is not user-replaceable. One consequence is that you cannot reboot the camera by removing/reinserting the battery.
No. You'd need one of these:
Arlo Essential
Arlo Video Doorbell
