- English
 - Cameras
 - Arlo Essential Indoor Camera
 - Re: Camera stopped working with app, says offline ...
I am at work so I cant tinker with it, but I just got it and already its been having issues not recording.
Try power-cycling it when you get home.
It just loads forever.
@Nemmy wrote:
What is power cycling?
Unplug the power, and then reconnect it after a few seconds.
It says it is connected to wifi but how can I be sure? Is there an icon? There is a wifi icon but its not lit up, is it supposed to be?
@Nemmy wrote:
It just seems to be working really poorly now, barely records anything and when it does its about 2 seconds before it cuts out.
If it's recording anything at all, then it is connected to wifi.
You could try a factory reset. https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
@Nemmy wrote:
It's showing a red light what does that mean?
Do you mean the status LED (to the right of the lens as you face the camera)?
It should be either amber or blue - solid amber does mean an internet connectivity issue has occurred.
@Nemmy wrote:
There is a blue light up top and then a red light below it.
That might be the IR spotlight (used for nightvision). Is the camera in a dark location?
I cant even access live feed. It just loads forever.
I want this to be a worthwhile purchase but it has been so overwhelmingly shotty and its just a few days old.
Did you try the factory reset I suggested earlier?
I cant even watch live feed.
@Nemmy wrote:
Yes, it says operation failed
What operation failed? The livestream?
Note this was a different suggestion from the power cycling. https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
And when I tried to watch live footage or even test the shield or something on the camera, would say operation failed.
@Nemmy wrote:
I removed the camera and set it up again, that article says its factory reset.
Your camera has a sync button, so you need to use the second set of instructions (holding down sync for 15 seconds... ).
@Nemmy wrote:
I did that, otherwise I couldnt have tried to use it again.
Just checking, as you can remove/re-add the camera without doing the hardware reset (holding down sync until the camera flashes amber).
It is possible that something has gone wrong with your camera hardware. So it might be time to contact Arlo support.
@Nemmy wrote:
My camera never blinked amber during the factory reset,
Then try the procedure again, and hold the sync down until you see it blink amber.
@Nemmy wrote:
I tried this many times now and the amber color will not appear, I removed and reset up the device multiple times, it still has issues.
You might need help from Arlo support.
						Arlo Essential
1  -
						Arlo Video Doorbell
1  -
