camera firmware download fail.
  • 12 Replies
  • 3391 Views
  • 6 In Conversation
wolfeeric54
Just purchased an essential 2nd gen indoor camera. The firmware upgrade failed about halfway through. Nowtthe camera is not functioning at all. Suggestions?
12 REPLIES 12
wolfeeric54,
Try factory resetting the device and then go through the onboarding steps again. Do you still experience the same behavior?
You can find steps to reset here: https://kb.arlo.com/000062560/How-do-I-factory-reset-my-Arlo-Essential-Indoor-Camera
wolfeeric54
I can't reset it. Nothing happens when I press the pairing button.
wolfeeric54,
Are you following the instructions linked above? You must press and hold the sync button for at least 15 seconds.
dlbpnw
I just purchased a 2nd Gen Essential Indoor Camera (VMC3060) to complement my existing system  of 6 cameras, a doorbell, and hub. During setup, the app (updated) recognizes the new camera, starts the pairing process and then:
1) The camera's LED blinks 7 times then stops.
2) The set-up bar on the app gets half way and then stops.
3) I get a failure to sync with Error Code:0
I have an eero wifi mesh. I have set it to 2.4 for set up to no avail. I have factory reset camera to no avail. I have tried joining guest network to no avail. I have tried joining my Comcast router directly and avoiding the eero, no avail. I have cellular data turned off on my phone, no avail...
What am I missing? Please help!
We're currently investigating reports from some user experiencing issues onboarding new devices. For more information and updates, see here: https://status.arlo.com/
dowajo
2nd gen essential outdoor camera to add my existing system of 4 cameras, a doorbell, and a hub.
I also have and Eero mes
1) The camera's RED LED flashes then stops.
No other Arlo device I ever installed has given me problems during install, they just work.
We're aware that some users may have experienced issues onboarding and live streaming to their Essential 2nd Generation, Pro 5 and Security System devices. Our team has worked to resolve those issues and you should now be able to proceed with onboarding and live streaming your device. We recommend charging your camera for at least 30 minutes before starting the onboarding process.
If you are still having difficulty getting your device connected or accessing your device’s live stream, please contact us through the Support tab in your Arlo Secure App (under Settings) to reach an authorized Arlo Customer Care expert or direct message us here with your Arlo account email address so we can follow-up with you directly.
We appreciate your patience while we worked to resolve these issues and apologize for any inconvenience caused.
-Arlo Team
wolfeeric54
I eventually pressed and held the sync button for 2 minutes.  There was no signs of life.
wolfeeric54,
I encourage you to reach out to support to further investigate the issue. You can find support by logging in to your Arlo app and navigating to Settings > Support to open a ticket.
donny1964
i bought 3 Arlo indoor VMC3060
new, straight out of the sealed boxes
the boxes were in mint condition too, no dents
i added 2 to my account
i updated firmware on the same 2
but the third 3060 refused to update
this i find very poor
especially from such a large corporation....
not good enough.....
donny1964,
When you say it refused to update are you seeing an error message? You might try removing the camera and re-onboarding again to see if you still see the same behavior. Follow the instructions here to reset the camera after you've remove it from the Arlo app: https://kb.arlo.com/000062560/How-do-I-factory-reset-my-Arlo-Essential-Indoor-Camera
