![](/skins/images/D711ADE526BEA1093298BA7B15BF22B7/responsive_peak/images/icon_anonymous_message.png)
I noticed recently that I haven’t been getting notifications for the last few days and noticed the app was set to standby. However I can’t turn it off.
Pressing "Armed Away" has no effect???
Nope
You might try Arlo support (getting phone support using the support center in the app).
You could also try removing the camera from your account and then adding it back again. If you do that, then maybe also try a hardware reset after you remove the camera. You do that by holding down the pairing button until the camera LED flashed amber (about 15 seconds)
I did all that and nothing still. I contacted support And because I don't have subscription the virtual bot brought me here.
I'm just gonna return it because it seems like the company wants your pockets then helping. (Customer satisfaction bad) rate 0 stars.
kccarba,
Take a look at the rules within each of your modes to see if there are any rules telling the camera to perform an action when triggered. For more information about how to do this, see here: https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
Arlo Cameras
audio
battery
Cable
Cord
Essential Indoor 2nd Gen
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
