Hello arlo Community,
Does the "Arlo Essential indoor 2nd Gen" come with a built-in smoke/Co detection? I know the arlo baby cam does.
Thanks in advance for your help
No. You can check the specs yourself here:
https://www.arlo.com/en-us/cameras/essential/arlo-essential-indoor-v2.html
While @jguerdat is correct in saying that the camera doesn't have a smoke detection sensor, there is a related feature it does have. The smart notifications include a "CO/Smoke Alarm". When this is enabled, the camera will listen for the chirps that a (nearby) smoke detector generates, and that will trigger the camera.
Arlo Cameras
audio
Cable
Cord
Essential Indoor 2nd Gen
Failed
New features
not working
notification
Plug
reset
resetting
support phone
Vmb5000
vmc3060
Wifi connection
