Arlo can’t find wifi network
Hi
This is so silly, but Arlo can’t find my wifi network, which everyone else can see, 10 feet from the router….
It’s a complete blocker - any suggestions?
@Enfin-Bref wrote:This is so silly, but Arlo can’t find my wifi network, which everyone else can see, 10 feet from the router….It’s a complete blocker - any suggestions?
Is your phone connected to your home wifi while onboarding?
If you use a VPN on the phone, make sure it is disabled during the install.
If you can disable 5 ghz wifi in your router while onboarding, then try doing that.
Thank you!
These age good suggestions.
yes phone is connected and no VPN. But maybe it’s a ghz thing. I’ll check
Arlo Cameras
audio
battery
Cable
Cord
Essential Indoor 2nd Gen
Failed
Indoor camera recordings
New features
not working
notification
Plug
reset
resetting
Stand
support phone
user manual
Vmb5000
vmc3060
Wall Mount
Wifi connection
