Arlo can’t find wifi network
  • 2 Replies
  • 2622 Views
Enfin-Bref
Hi
This is so silly, but Arlo can’t find my wifi network, which everyone else can see, 10 feet from the router….
It’s a complete blocker -  any suggestions?
@Enfin-Bref wrote:
This is so silly, but Arlo can’t find my wifi network, which everyone else can see, 10 feet from the router….It’s a complete blocker -  any suggestions?
Is your phone connected to your home wifi while onboarding?
If you use a VPN on the phone, make sure it is disabled during the install.
If you can disable 5 ghz wifi in your router while onboarding, then try doing that.
Enfin-Bref
Thank you!
These age good suggestions.
yes phone is connected and no VPN.    But maybe it’s a ghz thing.    I’ll check
