I have two Arlo Baby montiors in each of my kids rooms. I recently started using a iPad for the monitoring. The live feed screens are SO small. Being in landscape or portrait mode doesn't make a difference. Is there a way to make these bigger? I was using an Android tablet previously and the two live feeds take up the whole screen which I loved because I could actually see what was going on- super helpful when they wake overnight! I've attached a picture to show what I'm referring to. Thanks!
You are looking at the thumbnails. There should be a button to click to enlarge to full screen which I do not see on your image.
Open a browser and login here https://arlo.netgear.com/ see if you then get the enlarge button.
You do know that you have the option of zooming in to view close???
I know how to make each one full screen, if that's what you mean? But I want to be able to still view BOTH rooms at the same time. But they are so tiny on the screen.
I can zoom in on each screen, but the size of the viewing remains small.
Here is a view on the Android tablet... each camera/room takes up HALF of the screen. It is a HUGE difference now with the iPad. The images are so small.
I have exactly the same problem, on Windows PC its ok, on iPhone to but on iPad they cover 25% off the screen, the rest is just empty. The pictures are tiny
Arlo Baby
