Using Arlo Baby with Arlo Q or Pro2?
I would like to place the Arlo Baby in the Nursary, one of the Pro2/Q at my apartment entrence hall and the other at the backdoor. All have access to wifi network. But I'm just wondering what's the backup if wifi does become unstable, will I still have security footage?
1) All Arlo cameras are managed by the same app so adding and mixing and matching is fine.
2) If WiFi dies, the Q would stop recording. The Q+ has the ability to use a microSD card so no WiFi would still allow recordings (it also supports Ethernet connections so WiFi wouldn't be an issue). The Pro 2 would be able to keep recording if you use a USB drive on the base since your WiFi is separate from that used by the wireless cameras. In both cases (Pro 2 and Q+), you have to eject the card/drive to be able to view any videos on a computer.
3) Right now there's no dedicated monitor. You can use an inexpensive tablet in its place. The Amazon Fire HD 8 has been suggested. ALso, it depends on what you expect to monitor since only the Baby will keep on streaming live without timeouts.
1) Yes, they will all appear in the same web page or app... keep in mind the Q and Baby hook into your wifi directly while the Arlo Pro2 hook into the base unit only
2) the Q Plus can use a mem card like the Pro2 base ( usb speedstick ) for backup of files when the interent is dropped ( must be setup prior to loss ). The Q camera does not offer this option
3) No...they had planned to but later dropped this as tablets ( like the Kindle Fire (new version)) were cheap enough it prob didn't pay... apps work on android and iOS and web directly
4) Pro/Pro2/Q Plus record to the cloud and the mem card/usb drive port( as a backup only) at same time. To view these file you must remove the storage device and place into computer to see mp4 files. If internet drops it will still continue to record ( but will not backfill to the claoud )
Arlo Baby
