- 2
All of a sudden today the option to change the wifi connection for my Arlo Baby’s. When I go to “Device Settings” the only thing there is “Device Info” there’s no option for “Wifi Settings” anymore.
32 REPLIES 32
Problem still isn’t fixed. I can’t connect to another WiFi with the Arlo app. I only see hardware and serial number.
Message 26 of 33
1,363
Version 3.5.6 of the Arlo iOS app does seem to fix the issue for me.
Message 27 of 33
1,354
Can you verify which version of the Arlo app you are using in the app's (Settings > About)?
Message 28 of 33
1,354
Hello, I am having the exact same issue, have you found a resolution yet?
Message 29 of 33
1,320
Did you confirm you have the latest app? 3.5.6… that’s what fixed it for me
Message 30 of 33
1,319
Yes, i have the latest app downloaded (3.5.6). I can change the Wifi when i am on a Wifi network. But the option disappears when i am in the house of my parents. I have done a re-install just now, hopefully this will fix it for next time. The last time my wife had to change it trough the web portal.
Message 31 of 33
1,304
Can you download the latest version of the Arlo app 3.5.8 & test again.
Thank you
Message 32 of 33
1,217
Yes. It works now. Thanks for the support.
Message 33 of 33
1,216
- 2
Arlo Baby
