  • 10 Replies
  • 3290 Views
wtn1239
Thank you for fixing the audio on Arlo Baby but ver. 261 now brings a major problem and it’s the only reason why I bought Arlo.  When you set the temperature range I am not getting PUSH alerts anymore on my I-phone only e-mail when the temperature goes above what I set.  This puts my pets at risk now.  I never had a problem getting push alerts before?  I am getting puch alarts from motion and sound just not for Temperature, Air quality and humidly.
Thank you
10 REPLIES 10
ShayneS
wtn1239,
Have you tried to reboot your Arlo Baby? What iPhone & OS are you running? Do you have the latest firmware version on your Arlo Baby?
wtn1239
No I did not reboot everything elce is working fine. I am useing I-phone 5S IOS 12...I have firmware 1.8.5.3_21226.......
ShayneS
wtn1239,
Can you try a reboot and test your Arlo Baby again?
wtn1239
I went to test the temperature Threshold setting by trying to lower the max temperature on the slide bar and found I can not adjust/move the settings while in fahrenheit mode with your new update app 2.6.1.  This could be where the problem is because I did not get the push notification when it got warm in my house. Thank you.
wtn1239
I got the temperature bar to move but now the lowest temperature I can set it to is 93F. Please look at this slide bar. Thanks
ShayneS
wtn1239,
Is this the IOS 12.1 you have installed? I was not able to replicate this issue with an iphone running 12.1 iOS. Our slide bar was working as intended.
wtn1239
Please see attached photo. I am running IOS 12.01
ShayneS
wtn1239,
Apple has released iOS 12.1. I see you mention using 12.01. Do you mean you have the most up to date OS 12.1?
wtn1239
Please just fix your App I can not lower the temperature below 93 degrees.
ShayneS
wtn1239,
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
  • 10 Replies
  • 3291 Views
