Offline. Not located
  • 2804 Views
BIGsister181
Recently my arlo baby went offline. The 2nd time it happened, I am not able to locate it anymore. I have reset the camera & the base station. Unplugged both overnight.  Restarted the camera. Synced both. Done these things several times. Also, every time I try to locate my arlo baby, my Honeywell thermostat disconnects from the wifi. Something that has absolutely nothing to do with arlo. I also turned the thermostat off, but that didn't work either. HELP, I desperately need this camera back on.
ShayneS
Have you tried factory resetting the camera via this article here: https://kb.arlo.com/1282685/How-do-I-reset-Arlo-Baby-to-factory-default-settings
BIGsister181
does the power need to be on or off for that to work?
I also cleared the cache but not the data. Not sure if doing either will help or make it worse.
ShayneS
The camera will need to be plugged in to power to respond.
  • 2804 Views
