Notifications from Arlo app has changed to 12h (from 24h)
  • 1369 Views
RoGi01
Hi,
I´m having issues with my push notifications from the Arlo App and I´m not really sure when it started, but I think it might have started with the update to iOS 15.3.1.
All my notifications is now tagged with 12h (am/pm) time and not 24h like I used to have. Can´t find any settings for this in the Arlo app. Time stamps within the app are still correct (24h), just the notifications that are wrong.
I have checked that the correct time zone is set, restarted phone and camera. Logged out/in of the app.
Any idea how I can change the notifications back to 24h?
Running on iOS 15.3.1
Camera HW: ABC1000r6
FW: 1.10.0.0_931_812eee7
App version: 3.5.12 (3220)
ShayneS
Can you try and remove/reinstall the Arlo app & change the TZ then switch it back to your TZ?
RoGi01
Thank you @ShayneS for your answer.
I have tested this, but still the same issue. Notifications are still in the 12h format.
ShayneS
Does adjusting your phones time settings and switching back help?
  • 1370 Views
