Does the baby camera still work with homekit?
I have an arlo baby camera that’s a few years old. I’ve been unable to get to connect with homekit. Does anyone know if this is still possible and any tips?
Thanks!
Hi @t1ress
Thanks for reaching out, can you provide more detail regarding the symptoms you are experiencing? Do you receive any error messages?
Hello ShayneS, I have the same issue. There is no homekit settings available under device settings. The unit has been owned and used for a few years with it intermittently working on homekit till I removed it about a year ago. I would like to add it again but it is not showing the option of doing so. Homekit will not add by setup code either. Thank you
Can you try removing and reinstalling your app then reboot the camera and check again.
https://www.arlo.com/en_be/support/faq/000054805/How-do-I-set-up-a-new-Arlo-Baby-camera-with-HomeKit
Arlo Baby
