  • 6046 Views
t1ress
I have an arlo baby camera that’s a few years old. I’ve been unable to get to connect with homekit. Does anyone know if this is still possible and any tips?
Thanks!
ShayneS
Hi @t1ress
Thanks for reaching out, can you provide more detail regarding the symptoms you are experiencing? Do you receive any error messages?
AvonBarksdale
Hello ShayneS, I have the same issue. There is no homekit settings available under device settings. The unit has been owned and used for a few years with it intermittently working on homekit till I removed it about a year ago. I would like to add it again but it is not showing the option of doing so. Homekit will not add by setup code either. Thank you
ShayneS
Hi @AvonBarksdale
Can you try removing and reinstalling your app then reboot the camera and check again.
https://www.arlo.com/en_be/support/faq/000054805/How-do-I-set-up-a-new-Arlo-Baby-camera-with-HomeKit
  • 6047 Views
