  • 5 Replies
  • 1842 Views
eliotran
I have an Arlo Baby, ive used it for 4months it worked perfectly but my network changed and it stop working. Ive made a new account and it worked for a couple of weeks only.
I have gone through the setup process on the app with n.. The camera will chime once it reads the QR code, after that it will not discover the device. I have gone through the setup many times with no luck, I have also tried reseting the camera as suggested.
5 REPLIES 5
JessicaP
Hi eliotran,
I would suggest to try power cycling your Arlo Baby to see if that helps, which you can read here to learn how to do so: How do I power cycle my Arlo Baby camera?
And then try onboarding the camera again and make sure you're connected to your WiFi network on your phone device.
MikeCips
Hi,
I’m having the same issue. I’ve power cycled and hit the reset button. The app won’t discover my Arlo baby cam. Even when I try the QR code setup, I hear the chime but then still won’t discover the camera.
JessicaP
Hi MikeCips,
Make sure you typed in your WiFi SSID and password correctly (both are case-sensitive). And make sure that your phone device is connected to the same WiFi network you're trying to pair your Arlo Baby with.
MikeCips
Hello,
I checked all of those factors and they are correct. I’m not sure why it’s not connecting. Would the battery inside have anything to do with it?
JessicaP
You can try to power cycle the Arlo Baby and try connecting again. You can read here to learn how to power cycle: How do I power cycle my Arlo Baby camera?
Otherwise, I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 5 Replies
  • 1843 Views
