Hello!
I have a problem with my arlo baby camera. It will not charge neither let's me to a reset or sync. If plugged in to a charger in some position the orange light is on but that's it. Nothing else can be done.
I am out of ideas. The camera is about 1.5 years in use.
7 REPLIES 7
Make sure you are using the original ac adapter for the baby
Also, check the battery switch under the feet.
Solid yellow means the Baby is booting ( is it blinking at all? )
I am using the original ac adapter allthough the original cord is very loose and I tried with other cords but still no luck.
Solid yellow at all times, no blinking.
And, you have held in the reset for at least 10 secs ??
Yes, 10sec and twice even more.
Sorry, don't have anything else.... except your stated loose cable. Try a different cable with original adapter
All ready tried..
How can i send my cam to warranty check?
@kertur wrote:
All ready tried..
You can contact Arlo support.... but most warranty for Arlo ( IIRC ) is one year.
Arlo Baby
