Arlo baby - device not being discovered. Had reset device and both app and phone are on same WiFi.
Hi,
We just purchased an Arlo baby second hand. I am trying to set it up using the app however the app doesn't seem to be discovering the device. I had reset the device, both my phone and the app are on the same wifi and I do get the chime with the QR code.
Could I please get some help with what may be causing the issue? Its really frustrating and I don't know what else to do.
Thank you.
first here;
https://www.netgear.com/images/pdf/arloproduct/arlo-baby-user-manual.pdf
Then be careful that the router does not use special characters in the pw
@TomMac wrote:https://www.netgear.com/images/pdf/arloproduct/arlo-baby-user-manual.pdf
Not sure how long Netgear will leave that up. The Arlo-hosted manual is here: https://www.arlo.com/en-us/images/documents/arlobaby/arlo_baby_um.pdf
Hi LisaMarie143,
Have you tried what TomMac/StephenB suggested above?
Worked for 9 months and stopped. I've power cycled, factory reset, and removed the device from account but to no avail
The frustrating thing is that I get a solid blue light and the MAC address shows up on my network. But phones, tablet, and PC all cannot discover the camera
Hey jutitoo,
What error message are you seeing when trying to stream your Arlo baby?
You mentioned you got it replaced by the support team. Let me reach out to you via private message to gather more information from you.
Arlo Baby
