Arlo baby Camera charging wire broke. Where can I get a replacement?
Hi all,
My arlo baby bunny monitor has a broken charging wire which i need to replace. Does anyone have any idea what this is called or where i can get it from? Can only find one on amazon for the arlo pro/pro 2.. would this be compatible?
Thanks!
Have you tried a quality micro usb cable? I haven't swapped the cable but it appears to be a standard micro usb from my experience with it
Really, I will give that a try thank you so much!
Arlo Baby
