  • 10 Replies
  • 8507 Views
Danot7
My brand new $399 AUD Arlo Baby is painfully slow.
It is connected to the same WiFi as my iPhone, yet the home icon does not show.
It actually seems to work better if I turn the WiFi on my phone OFF...
10 REPLIES 10
I would do a reset of the Baby and resync it again.
Danot7
I've had 4 goes at it.
Could it be a setting with the router?
Not the router, but a good possibility if your data thru-put is low... these cams can peak at >1.5Mbs.
Danot7
How do i change it? It'll have to return it I think.
run a speed test.... http://www.speedtest.net/
it will tell you how fast your data is
Danot7
Ping: 20ms
Download: 17.44mbps
Upload: 1..25mbps
Streak2
Master Master
If things on your phone work better with wifi off ie. using data only, then there is a problem with your wifi at the location where you are trying to use it. This would have nothig to do with the Arlo baby. Have you tried doing a speedtest by plugging a computer directly into your router using an ethernet cable?
What is the wifi signal strength in the room and the same position where the camera is located. Hold your phone nearby and redo the speedtest.
I assume you're doing the reset correctly?
https://kb.arlo.com/1282685/How-do-I-reset-Arlo-Baby-to-factory-default-settings
Danot7
Speed test was in the same spot as camera...
Yes reset correctly.
Streak2
Master Master
And what's the speedtest result when a computer is plugged directly into your internet router?
A new Arlo Baby firmware was just released. Make sure your Arlo Baby is up to date on the latest firmware and test again to see if you are still experiencing the same behavior.
Release Notes – Arlo Baby 1.8.0.31_13810 – 9th August 2017
  • 10 Replies
  • 8508 Views
