  • 4 Replies
  • 2111 Views
LjCa
I have an the Arlo Baby camera I pick up these loud clicking and banging noises. It happens day and night sporadically. Does anyone else have this problem any suggestions? No I haven't moved it from the room yet to see if it still does it, I'm going to try that and see if it remedies the problem
kingfamilysf
Yup
One of our Arlo baby cams has constant sounds I would associate with the sound of a hard drive writing/reading
When we are away on vacation and there is no sound at all the same camera picks up a bang every 2 hours it is engaged.
The other Arlo baby does neither.
ShayneS
Hi @kingfamilysf
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
kingfamilysf
@ShayneS
Other than rebooting, none. Send whatever you think might help.
ShayneS
I would suggest performing a factory reset. To do this you can do the following: How do I reset Arlo Baby to factory default settings?
If this does not help,  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 4 Replies
  • 2112 Views
