Arlo Baby keeps skipping lullabies
The sounds are loaded but skip before playing. I click on one to play and it doesn’t even start before skipping to the next which doesn’t play and skips to the next continually.
HI @cel13
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
I have restarted it multiple times, uninstalled and reinstalled the camera, tried clearing my playlist and readding sounds - when I do that then none of the sounds work so I haven’t tried that again, and changed the network the camera was on. Not sure what else to do!
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Arlo Baby
