Arlo Baby is stuck on orange amber light and i cannot seem to contact anybody for help
My Arlo Baby is stuck with an amber light, have tried everything and I cannot get it to work. I have also looked for everyway to contact support and all I get is a chat bot that cannot help me with anything
Support is most easily found using the app by going to Settings, Support. At the end of the chatbot, answer the questions which can put you in touch with an agent.
Untrue.. I cannot be put in touch with an agent. How can I get my money back? Completely unsatisfied. I have used it for exactly 3 months and it no longer works!!
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Arlo Baby
