Arlo Baby Won’t Connect And Sync
  • 11238 Views
  • 3 Likes
jamy1985
Hi,
My arlo baby all of a sudden will not connect to the wireless network and is amber flashing.
I tried factory reset and removing device from phone and re adding but also does not work. I ensured I am on same network..
The message I’m getting is after arlo discovers device, I click on network, then the device tries connecting, it seems to connect to the wireless network but when it then starts to connect to the arlo baby, it takes a while then I get an unexpected error.
Tried so many times but still doesn’t work.
Arlo Baby is so unreliable, wouldn’t recommend to anyone as a baby monitor.
Power down and make sure you turn off the battery ( under feet )
wait a few mins and plug into ac power, do a full reset ( hold reset for 10 secs till led flashes ) and attempt to sync as if new
jamy1985
Tried and done that. Unfortunately still doesn’t work.
ShayneS
jamy1985,
Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
  • 11239 Views
  • 3 Likes
