  • 4 Replies
  • 3106 Views
ekoplitz14
My Arlo Baby drops the WiFi connection at least once a day and has been doing this for over a week. I just checked and the firmware is the current version which should be 1.8.5.3_21226. I thought maybe it was the app on my android phone, but it isn't because when I login to the camera through a web browser, it says the camera is not connected. The WiFi connection is strong and all other devices that connect to the WiFi do not lose connection to the internet so it is not my router or cable modem.
Contact Arlo via the support page and advise them... they may have a newer field test version of FW to send you
In the meanwhile , maybe you should do a reset of the baby
eatoff
I had a similar issue, I asked around on some forums and it was suggested I disable airtime fairness on my router, and 48hrs later my Arlo hasn't had an issue. Maybe the latest firmware doesn't play nice with that setting, I'm not sure. Check what model router you have and see if it has airtime fairness, and if you can disable it.
ekoplitz14
Thank you for the suggestion, but unfortunately my Netgear router does not have that option. I did update the router for necessary updates but it appears that the issue is still happening as I cannot view the live feed online or through my app on my Samsung S9+. I have the option to view the music and temperature, but it just keeps saying buffering. This is frustrating to say the least.
ShayneS
ekoplitz14,
Have you tried contacting customer support regarding this issue?
  • 4 Replies
  • 3107 Views
