Arlo Baby Temp/Humidity/Air Quality Alerts
  • 2 Replies
  • 3149 Views
jaydayclay
Hi All,
Has anyone found a way to disable the temp/humidity/air quality email alerts? I only want to receive push notifications for them, but it appears you can only turn those type of alerts on or off and not actually select what type of alerts you want to receive. This is different behavior from the motion/audio alerts where you can choose how you'd like to receive the alerts. Hopefully I'm just missing some burried setting. Thanks!
JonWs
Great question. I don't have an answer but wanted to add to the question, basically where are the temp, humidity, air quality alert settings? I want a push notification not an email. Also I'd like it to also be pushed to my wife's phone, and even the nanny's phone not just mine. Maybe this hasn't been developed yet. If not, would be a much appreciated enhancement/upgrade.
jaydayclay,
Currently, these alerts (push notification and email) are both either on or off. There is not a way to enable or disable the alerts separately.
  • 2 Replies
  • 3150 Views
