  • 9 Replies
  • 12312 Views
  • 3 Likes
  • 8 In Conversation
redbeardjake
I've Arlo Baby since last Friday and the nightvision stopped working two nights ago. I have already confirmed in the device configuration menu that nightvision is select on. There are no lights in the background that was cause potential issues with the IR sensor. Various individuals have the same issue and I've already tried taking battery out and putting it back in. Any other ideas before I send back?
tunguyen
Hi @redbeardjake,
A new firmware version 1.8.0.27_12874 was released last night (May 21) and should address the night vision issue you are experiencing. The firmware should have already been uploaded onto your camera. Have you had a chance to use the camera today? If yes, are you still seeing the issue?
Thanks,
Tu
9 REPLIES 9
Is there a reset ?
redbeardjake,
Engineering is currently investigating a potential issue related to Night vision. What mode is your Arlo Baby set to. If set to "Monitoring On" do you see the same behavior?
Joelprado
I'm also experiencing the same issue since day one that I received the Arlo Baby. I have several other Arlo cameras including the Q and this does not happen. When I log in, it seems to work fine for about a minute and then it goes dark and you can hear the night vision shutter click off. If I go out and then back in it's still dark unless I use a different device the night vision will work but then go dark after about 30-60 seconds. Very frustrating given the purpose of this camera is much more important than the other Arlo cameras we have. Please help.
Laladingdong
Check to see if there is a firmware update. Mine had one. Since the update night vision works a little bitter, but still garbage. 1.8.0.25_12698
gmsne
I'm pretty impressed by the night vision on ours and haven't experienced issues with that feature.
I don't have any of the modes turned on, I've been adjusting settings manually so far.
tunguyen
Hi @redbeardjake,
Thanks,
Tu
Joelprado
Yes! As of last night it's working. Thank you very much!
tunguyen
Awesomel! Thank you for confirming. Please feel free to email our Product and Engineering team at arlobaby@netgear.com if you have any questions or feedback.
-Tu
  • 9 Replies
  • 12313 Views
  • 3 Likes
  • 8 In Conversation
