Arlo Baby - Monitoring Turned Off Every Day
  • 7 Replies
  • 6049 Views
  • 5 In Conversation
niko73
Everyday, my arlo baby is disarmed from monitoring and i have to reset to to armed.  any ideas what's wrong?  I don't have any type of scheduling set.  i just want it monitoring all the time.
7 REPLIES 7
I would uninstall it ( remove device ) and bring it back as new to eliminate any possible glitches
Also, may consider a factory reset to be sure all is good..and then bring back
Skijosh
I'm having the same issue. I've uninstalled the camera twice and done two factory resets and nothing is fixing the issue. Started in the last app update (not the one today).
ShayneS
@Skijosh
  Have you tried contacting customer support regarding this issue? I have attached the link below for you - Arlo Tech Support
joshweiss16
I'm having the same issue again too. I just did a warranty exchange. My first arlo stopped working all together after trying to reset it to fix this issue. After awhile it wouldn't record anything. Now the new one won't keep monitoring on either.
ShayneS
@joshweiss16
Is the firmware for the camera up to date?
joshweiss16
Yes both the returned Arlo and the new Arlo both had their firmware updated.
Skijosh
mine are also up to date - but not sure why you are asking about base station since Arlo Baby connects natively to wifi on its own.  I do have a base station for my other cameras.
  • 7 Replies
  • 6050 Views
  • 5 In Conversation
