  • 1618 Views
  • 2 Likes
Joe-Italia
Whenever Arlo Baby notices abnormal temperature/humidity/Air quality  I get an email notification and a push notification... I would like to specifically disable the email notifications and keep the push one active... So far the instructions say to go to the desired sensor and disable notifications however that will also disable push... Think there is an issue?
ShayneS
Hi @Joe-Italia
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Joe-Italia
I believe we need a fix for this as in a different interface somehow? Can't the community be of help? Seems like the tech support is all about resetting/changing settings/providing me with a new device....
FREEMAN38
It seems to be an enhancement request as it is not possible with the current interface
This difference between movement/audio notification and air quality notification is strange
  • 1619 Views
  • 2 Likes
