I have the arlo baby camera. The amber light is solid. Cannot use it. Spoke with multiple individuals had me do same rest. It will not work, just stays amber.
5 REPLIES 5
If you have tried this reset
https://kb.arlo.com/1282685/How-do-I-reset-Arlo-Baby-to-factory-default-settings
and it's still solid amber meaning that the camera is booting, then it may be faulty.
I tried that, it just stays amber. Is it some fault with the software? It was working just fine then it stopped.
I don't know where the fault may be.
Try turning the battery off and removing power.
Then power up again and wait to see what happens.
Try resetting with the battery off.
I made sure the battery switch was off. I tried letting the battery drain. Pressed the reset button, the light stayed solid amber.
Just to be sure, a RESET requires the button to be held in about 10 secs till the front led flashes
( not a press )
Arlo Baby
