  • 6 Replies
  • 2917 Views
Sommo
Hi,
Is there a way to chose only push notifcation for weather condition and to not receive email.
As I can see there is no ability to chose which recieve
6 REPLIES 6
Not for just for the air quality.... It's either on or off for all recorded conditions
adam1111
Hi,
I am receiving email alerts (for temperature, humidity and air quality) and I want to turn these off so I am only notified by PUSH on the app.
I that the "MODES" setting only give option for managing alerts for Motion or Sound but not temperature, humidity or air quality. I have email alerts turned off for Motion and Sound already.
How do I turn email alerts off for things other than Motion and Sound?
Have you TURNED OFF the alerts for sensor in that section?? (Click on sensor icon in web on live view screen)
Looks like this;
adam1111
Thanks for the suggestion but I'm worried if I do this I will stop receiving push notifications on my phone. Do you know if my assumption is correct or not?
JessicaP
Hi @adam1111,
That is correct where if you do toggle off "notifications," you will not receive both push and email notifications. However, you can post your idea here to have the email and push notifications separated: Idea Exchange Board
adam1111
@JessicaP wrote:
Hi @adam1111,
Thanks for the clarity Jessica. I will post the idea
  • 6 Replies
  • 2918 Views
