issue occurs
  • 8 Replies
  • 1435 Views
  • 7 In Conversation
mario779petri
Hello,
After the doorbell is pressed and rings, the light remains solid white indefinitely (or for a long time) and doesn't return to standby/no light. What is the light status on the doorbell when the issue occurs?
8 REPLIES 8
According to this, it means 2-way audio is in use:
https://kb.arlo.com/000061847/What-do-the-LEDs-on-my-Arlo-Audio-Doorbell-mean
You might want to remove/reset/reinstall it to see if that makes a difference.
https://kb.arlo.com/000061842/How-do-I-factory-reset-my-Arlo-Audio-Doorbell
I suggest removing/reinserting the batteries first.
anna78smith
When the issue occurs, the doorbell’s light stays solid white after being pressed and ringing, instead of returning to its normal standby state with no light.
BrookeN
Have you attempted to rest the doorbell?
buckaroooo
https://kb.arlo.com/000061842/How-do-I-factory-reset-my-Arlo-Audio-Doorbellblock blast
I’ve seen similar issues where a device appears to stay in an active audio state even when no one is using it. Has anyone figured out what causes this on the Arlo Audio Doorbell?
BrookeN
You can reset the doorbell and see if that resolved the behavior you are seeing.
renewalls0952
Hello, The doorbell’s light stays solid white for a long time after ringing and doesn’t return to standby. Has anyone experienced this issue or found a reliable fix?
BrookeN
Can you tell me what troubleshooting steps you have already attempted so I do not repeat any steps.
  • 8 Replies
  • 1436 Views
  • 7 In Conversation
