Just ordered the arlo doorbell and want to place it in an angle mount similar to the ones that are available for the ring doorbell. What's the distance between the two holes where the screws that are used for mounting the doorbell?
thanks
gbortoni,
The mounting holes are approximately 2 inches apart. The overall dimensions of the doorbell are 92x45x27mm.
gbortoni,
Thank you sir!
Hi @Jb74
We measured the Arlo Audio Doorbell backplate, and from the center of each mounting hole it was 1 3/4"
