Traditional Mechanical Chime doesn't respect Silent Mode
  • 9 Replies
  • 4730 Views
doenamite
I have installed the Arlo doorbell with a traditional, mechanical chime. Everything works perfectly. I receive phone calls and the traditional doorbell rings. However I found the silence mode in the settings and was actually surprised as I wasn't expecting this feature but the feature doesn't actually work. If I enable silence mode I don't receive phone calls but the traditional chime still rings.
Is the expected functionality?
9 REPLIES 9
JessicaP
Hi doenamite,
For the silent mode on Arlo Audio Doorbell, you can silent incoming calls and Arlo Chime but cannot silent existing mechanical or electronic doorbell chime.
doenamite
If it isn't possible to silence the traditional doorbell, the app probably needs to change as it does imply that you can
JessicaP
Thanks for that screenshot! When you toggle off the traditional chime, does your chime still ring?
doenamite
It does, I tried a number of combinations of different settings on and off but the chime always rings
JessicaP
Let me reach out to you via private message to gather some information from you.
ptmullett
I am having this same issue with my traditional chime not working on silent mode. Is there a fix for this?
JessicaP
Hey ptmullett,
Have you tried toggling the traditional chime on and off to see if that works?
ptmullett
Yes, it works intermittently. Never works 100% of the time. As an example, if I put just the call feature into silent mode, it will put the traditional chime into silent mode even if I do not have the traditional chime selected to be silent. Very buggy feature that does not work quite right.
JessicaP
If it works intermittently even when trying to toggle the traditional chime, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 9 Replies
  • 4731 Views
