Any firmware update to increase sound quality or volume on Arlo Audio Doorbell?
  • 1 Reply
  • 1643 Views
bluefoam
I'd like to add this to my Arlo Pro 2 system & have been watching some reviews to make sure I'm doing the right thing... It seems ideal for me, the only concern I have is that the volume on the speaker and mic seems low... My house is near a main road, so there will be some background noise...
Have there been any firmware updates to increase the sound quality, or increase the volume?
tom6
To avoid disappointment, I recommend reviewing all of the unresolved problems of this product, especially since the latest firmware update. Simply, the button doesn't work. The product can only be used in detection motion, and using that event to chime or call phone. Even then, as you'll see in the comments, there are multiple syncing issues. To date, Arlo has made no acknowledgement of the problems, and has not made any positive statement about plans to fix them.
  • 1 Reply
  • 1644 Views
